how do you convert to an EIA. file
Results 1 to 7 of 7
    Feb 2011
    Saugus CA
    53
    Default how do you convert to an EIA. file
    Hello guys,
    We just bought a 2008 510c-2 nexus matrix. It does not read our programs generated from Gibbs. I called Mazak they said we have to convert the file to an EIA. file The person I spoke to said all we had to do was to change it, well how do we change it we tried everything? Any helpwould be greatly appreciated!
    George
    Nov 2006
    FL
    1,159
    130
    175
    like this:
    12345678.EIA
    Aug 2011
    Toledo, Ohio
    1,670
    39
    578
    Right click on the program you want to convert and hit open with "Notepad"
    File
    Save as
    Under type click all files
    Type Program name .eia Click Save
    Feb 2011
    Saugus CA
    53
    okay so we were able to do this and got the machine to recognize the eia fie thank you! Now our next problem, when we opened up the program on the machine control the program was completely different with all kinds of weird characters ? what are wed doing wrong?
    thanks
    George
    Jan 2013
    Plainfield, Indiana, USA
    1,534
    1125
    792
    You need to use a mazak post within Gibbs. The program will still be written in g code format. The post should put the proper header info into your program as well as save it with an "EIA" file extension.
    Jan 2013
    1,534
    1125
    792
    As an afterthought, use your mazak to create a one or two line EIA file, save it, and look at it with notepad. This will give you the header format so you can edit the Gibbs file.
    Aug 2011
    Toledo, Ohio
    1,670
    39
    578
    Quote Originally Posted by George M View Post
    thanks
    George
    If you don't mind posting the program I will take look for you. We have only mazaks in the shop.
    I dont use a mazak post I just use haas post I slighty modified for tap cycle and couple other minor things
    You also could pm me
