Hello again folks!
This high pressure coolant is going to make me crazy! Now that it’s working as it should, I am having trouble within a program. Beat my head against the wall and can not see it for the life of me. Hoping one of you experts can spot the error.
Basically, the problem is that I have a through spindle coolant 82 degree indexable cutter and the profile of the insert creates long stringy chips that find their way into the coolant passages. I have tried an entire spectrum of feeds/speeds to cause that to not happen and to break the chip. I *was* using TSC (M51) My thought was to try the HP to maybe keep the chip out.
So I simply added M131 and M106 (on the same line and on different lines) with and without the M51. When that tool is called up, the HP does not come on. It *does* come on for the NEXT tool, which doesn’t have or need TSC.
So I thought I’d include my program to see what you think. My apologies for not having the lines numbered. I wanted you to see it as I wrote it without cleaning it up. Wondering if lack of line numbers could be part of the problem. I *did* remove any proprietary info.
I’ll add line numbers if it’ll make it easier to refer to things.
<124.1>
G90G80G17G20G54G94
(TWO PARTS OP1, TWO PARTS OP 2)
(LEFT TO RIGHT - G54,G55=OP1 - G56,G57=OP2)
(X0 LEFT SIDE OF PART)
(Y0 OP1 BACK OF PART - FIXED JAW)
(Y0 OP2 CENTER OF PART, -1. FROM FIXED JAW)
(Z0 TOP OF PART, 5/8" THICK)
(T16 21/32 .656 INDEX TAP DRILL)
(T08 3/4" 4FL CARB E-MILL)
(T02 82* LARGE INDEXABLE COUNTERSINK)
(T19 3/4-10 TAP)
(T10 LARGE MULTI INSERT 45* CUTTER - SAID D=.275)
N10T16M06(INDEX DRILL)
N12G55G90G00X13.187Y-1.M39
N14S3150M3
N16G43H16Z2.M8
M51
G81R.1Z-.7F5.(F6.23)
X10.687
X7.312
X3.812
X1.312
G00G90G98Z2.
N13G54G90G00X13.187Y-1.
T08 (PRIME TOOL CHANGER)
X10.687
X7.312
X3.812
X1.312
G80G00G90Z8.
M01
N10T08M06(3/4" 4FL CARB E-MILL)
N12G54G90G00X1.312Y-1.
N14S750(S1050)M3
N16G43H08Z2.M8
G83(G73)R.2Z-.374Q.05F12.
X7.312Z-.316
X10.687
G80G00G98G90Z2.
N13G55G90G00X1.312Y-1.
T02 (PRIME TOOL CHANGER)
X7.312Z-.316
X10.687
G80G00G90Z8.
M01
N10T02M06(82* INDEX COUNTERSINK)
N14S608(S650)M3
N16G43H02Z2.M8
M51 <== Turn HP coolant on
M131
M106
G83(G82)R-.025Z-.175P.09F1.6Q.075(F3.)
X10.687Z-.37
X7.312
X3.812Z-.175
X1.312Z-.43
G80G00G90Z3.
N12G54G90G00X13.187Y-1.
T19 (PRIME TOOL CHANGER)
X10.687Z-.37
X7.312
X3.812Z-.175
X1.312Z-.43
G80G00G90Z3.
(M09) <= Do I need to shut the coolant off here?
Without this M09 here, TSC works for all remaining tools, which they don’t need.
N10T19M06(3/4-10 TAP)
N14S400M3
N16G43H19Z2.M8
G84R.1Z-1.1F.1
X3.812
X7.312
X10.687
X13.187
G80G00G90Z2.
T10 (PRIME TOOL CHANGER)
G84R.1Z-1.1F.1
X3.812
X7.312
X10.687
X13.187
G80G00G90Z8.
M01
(OP 2 CUTS 45S ON BACK SIDE)
N100T10M06(BIG 45*)
G56G00G90X15.3Y-1.5
S2400M03
G43H10Z2.M08
Z.1(M51)
G01Z-.185F30.
G41D10Y-1.
X-.65
G00Y1.
G01X15.3
G40Y1.5
G00Z2.
G57G00G90X15.3Y-1.5
T16 (PRIME TOOL CHANGER)
Z.1
G01Z-.185F30.
G41D10Y-1.
X-.65
G00Y1.
G01X15.3
G40Y1.5
G00Z5.
M9
M5
G91G28Z0.Y0.
M6T2 <== I just added this to bring the 82 deg cutter back up so I could check it for chips in the coolant passages.
G57G00G90X0.Y-6.
M00
G91G28Y0.
#3901=#3901+2
M30
