will_0000
- Dec 16, 2012
- Great Britain
Running a program that requires a number of ID grooves, Groove is 37 ID 44 OD 4.80 wide. Top header in program states 9.5mm minimum bore as there is a small bore at the back of the part, front is bored out to 37.0. When the grooving tool comes in it does so at 9.5mm which will cause a crash with the back of the tool. I want it to come in at clearance to 37. if I program 37 minimum bore it works fine but the rest of the program has illegal cutting points. How do I set the approach size for an ID groove.
Will
Will
