ASARGENT
Cast Iron
- Feb 6, 2007
- DAVIS, ILLINOIS
has anyone ever had tool clamping issues with their integrex 200y. it is a mark I model (about a 2001) and started having problems holding size sporadically. now it is every 10 pcs. you can fit a shim stock between the tool and the spindle when it does not clamp up right. we had mazak out today and they went through and realigned the tool changer arm, which did nothing (thought it could be causing it to load it incorrectly and clamp up funny) tool arm was off a bit, but was not the culprit. they want to tear out the entire turret and spindle and ship it to kentucky for a rebuild fee of $13000 or send us a new one for $24000 with a 15% core refund. WOW!!! i want to be sure that this is necessary. its not like its a $3000 repair and we can just take our chances. we can get the internal parts, springs, drawbar, clamping balls etc, but it wont do us any good as mazak refuses to tear down the spindle at the machine. they say that is against their rules to do this repair at our shop. the parts only total $3500. not to mention, once they tear out the turret we are going to have to replace all of the expensive o-rings that go on the turret shaft. anyone got any last ditch ideas before we bow before mazak and give them the 13 or 24 grand plus labor and additional parts? thanks in advance if you do. (and please dont say burn the machine, cause i already ran that through my mind)
