countryboy1966
Hot Rolled
- Jan 10, 2009
- Thompson, Ohio
I put 5 hrs into trying to figure it out and no luck.
Mazak QTN-100 Mazatrol Matrix Nexus Fusion control.
Im trying to do a back turn of sorts so I can machine a .25 Semicircle in one work holding so everything is true. I cannot get the programming to work for me even using the back turning unless I change the workpiece size to stop the excess machining. I tried all sorts of combinations, but I'm missing the boat on this. I figured I would attach what I consider the closest I've made it to making the feature. I'm trying to machine the part feature (Left side .125R) that isn't showing a tool path in the tool path photo.
I am attempting to make the feature with a .125W Top notch square face groover. Starting to think I should see if a full radius groover is available for the tool holder, but that is an improvement idea as I don't think it would resolve my programming issue.
Anyhow, attached are the photos of the program, tool path, alarm code (722 Illegal Corner Definition), and part dimensions.
Let me know if you can help me. Thanks.
