I'm trying to teach myself Mazatrol on my mill I just got in. I have all the manuals for this machine, but the programming book really sucks. It's vague and does not have explanations for a lot of things.
So far, I feel pretty good about drilling so I moved on to endmilling.
I have an old block (6.875x5) that i figured id see about facing with a 3/4 insert mill. I can't get it to run at all. I get a 685 alarm that says "square cannot be defined"
The manual shows the tool path going back and forth over the part (even funky shaped parts which is pretty cool) like it will calculate it's cut path based on part shape/size and tool size.
Here's a screen shot.
I was trying to start at the lower right corner of this block (X+, Y-, origin is center of block) and have the cutter make a pass across, retract and rapid back to X+ and make more passes until the block is faced.
Where am I going wrong?
Thanks!
Thanks!
