Results 1 to 5 of 5
    OKIEMACHINIST is offline Aluminum
    Jan 2006
    OKLAHOMA
    110
    Default Machine Not powering Up
    We have an Integrex 400Y with Fusion, when we came in this morning and hit the power on button nothing would happen. Screen will not come on and none of the servos lights come on as well. Power coming into the machine checked good and when we turn on the main breaker the cooling fans kick on. Checked the On Power Switch on the front of the screen and it is making good contact. I suspect a power supply, but not sure which one to check. Any ideas or suggestion would be greatly appreciated.
    Thanks in advance.
    Leelund is offline Aluminum
    Mar 2008
    Northern Kentucky
    133
    When you turn the main breaker on, the servo drives should show an Ab (I think) on them until the pc boots up and they initialize. Power supplies should have led's on or something. Nothing is alive in the Electrcal Cabinet after the main breaker except the cooling fans?
    Justin_Terry is offline Aluminum
    May 2009
    The Woodlands, Tx
    173
    I would check the 24v power supplies. Cant recall exactly where they are at on a Int 400. I want to say they are on the bottom right of the electrical cabinet. I'm working on one today I'll look and see.
    If you could check and see where you have power and where you don't. that would help out. seems like you have 100v but no 24V.
    Justin Terry
    May 2009
    The Woodlands, Tx
    173
    the 24v power supply is in small electrical cabinet on the back of the machine. It is on the very bottom. There is a green LED on it to see if it working. Let us know what you find.
    Justin Terry
    Jan 2006
    OKLAHOMA
    110
    Yep, turned out to be a dead power supply. Ordered one from Mazak and installed it and it fired back up. Thanks for your help.
