Results 1 to 11 of 11
    D. Rey is offline Titanium
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    How do I use the "tailstock teach" function on a T2 lathe control?
    I've tried setting it at 0, and moving the tool tip here and there, resetting. Everytime I do I seem to make the machine think that the tailstock is 15 feet long and get constant alarms.
    There is NOTHING in the operator manual about how to use this function. Nice.
    Anyone know?
    PTDAVE is offline Junior Member
    Jan 2005
    Bountiful, Utah
    25
    Post
    On our slant turn 40 when you get thru moving the tailstock to position needed. You unlatch the locking pin and push teach. By doing this it teachs the "machine positon" diminsion measured from the chuck. By putting "0" in the tailstock block it thinks that the tailstock is next to the chuck. What does your graphics look like when you do this? If your graphics do not look correct you have not taught something correctly. All things such as chuck data, tool data, tail stock data, chuck barriers all must be taught correctly or you are setting yourself up for a carsh. you can always run with the "barrier cancel" BUT you better be sure everything is correct.
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    Oh I'm not running anything until I get all of this straight, I'm not in any hurry. Baby steps are fine.
    So I set the tail where I want, hit "tail barrier teach" and then "input"?
    No numbers go in there?
    I'll try that....
    Appreciate the response
    Dave
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    Nope does not work.
    My machine has a manual tail stock carrage. The tail piston is what moves(only). There is no readout of position for this.
    I'm guessing that the tail barrier has something to do with the position of the turret in z or x, I don't know what this relationship is.
    HuFlungDung is offline Diamond
    Jan 2005
    Canada
    6,096
    Post
    Dave,
    Are the barriers a function of carriage and cross slide position? Move the carriage and tool slide as close as you dare to the tailstock, then teach these positions?
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    Nope tried that, I get "tail barrier" alarms every where. That's the way I figured it worked, put the turret close to the tail and say "don't go any further than this. Can't move the turret anywhere without the alarm.
    Must be some other way.
    Jan 2005
    Bountiful, Utah
    25
    Post
    On the program file page do you have a space to intput tailstock information? Are you looking at the space on the command page to input something refering to the tailstock? Do you see the tailstock displayed in graphics on a simulation page? ON our slant turn 40 you have space on command page to teach a distance from chuck to moveable tailstock. You also must input how far the pistion is extened out of tailstock on the program file page. I will send you more information from work in the a.m. about setting our tail stock. Might help then again might confuse you even more. Check your operation manual about the display of screen for the command page and see what it says about the space for tailstock. [img]smile.gif[/img]
    Bobw's Avatar
    Bobw is offline Diamond
    Feb 2005
    4,317
    Post
    Nervis, we have a '98 with an M+, I know its not the same controller, but on the position screen there is a button for "barrier cancel". It just shuts off the tailstock barrier limits, good to go, just don't run into the tailstock. I've never bothered to try and reset the barrier limits, I just shut it off.
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    Yep thank god you can cancel the barriers. I would be dead in the water if not.
    I don't know if I'll use them or not...just want to know how in case I do.
    dalewrc30 is offline Plastic
    Oct 2004
    New Zealand
    26
    Post
    it may be that you need to move the tailstock to where you want it measured,bring your tool up to contact it ,press teach then input 0.
  11. #11
    wippin' boy is offline Diamond
    Sep 2005
    il.
    5,058
    Post
    have you got a parameter book
    maybe the tailstock is described poorly
    i've got the same machine as you here
    i can get an application boy to explain.
    if you want you can call 847-885-8311
    ask for application
    just don't tell them your not chicago area
    i've got parameter books for your machine
    if you need them
    get used to calling mazak
    they have great support
