xa-mont
Hot Rolled
- Apr 4, 2014
- Victoria, Australia
Hey guys,
I have got my 4th axis retrofit all hooked up and got the correct parameters from an awesome tech in Melbourne (philip edmond, was half of alltech but is branching out now)
where I'm at now is that I can get it to work but I cant get it to home.
When i start the machine and I home the other 3 axis they work not a problem, when I press 4- to home the 4th it releases the brake on the 4th, and then does nothing else. no movement at the actual 4th, no change in position on the screen.
HOWEVER - if i then switch into 10x or 1x for the handwheel I can rotate the 4th and both the actual 4th moves and the indicated position changes.
I have checked the home pos switch in the 4th and it's working fine. (can handwheel it on and off) and the signal is received back at the TB1 strip, so cabling from the 4th to the machine is fine.
any ideas here?
I know the 4+ and 4- buttons are working fine, as i checked through the diag for that input and it trigers not a problem (also they both trigger the m44t relay to release the brake)
Trav
any ideas here?
Trav
