Results 1 to 10 of 10
    socketboy is offline Plastic
    Mar 2009
    OZARK MOUNTAINS USA
    Exclamation Mazak M4-1000 with 6T Fanuc- Need Manuals
    Have the machine powered up, but goes into cycle hold when we reach any M function related to spindle rotation in program mode. Spindle will operate in jog mode. Spindle controller ready light not on. Feel that is problem, but do not have any manuals to sort out problem. Would like to purchase schematics, machine parameters to double check or help solving this issue. Machine was purchased in Tulsa, OK. and installed here in my shop in Missouri. Would like very much to get this machine operating. Any help will be appreciated.
    routlaw is offline Plastic
    Apr 2007
    atlanta, ga
    48
    What is the type spindle drive amp? Does the spindle run in MDI?
    Mar 2009
    OZARK MOUNTAINS USA
    Routlaw, thanks for reply. MITSUBISHI DIAROL/DL-SCZ spindle controller and your second question, NO, the MDI does not function at all. Your help is greatly appreciated. WHAT NOW!!
    Speedie's Avatar
    Speedie is offline Hot Rolled
    Feb 2009
    Midwestern MN/Wi USA
    603
    Are you sure it doesnt look for any sensors like tailstock or quill in position? Do you hear and clicks in the selenoids?
    Apr 2007
    atlanta, ga
    48
    Make sure you have a gear selected and that he spindle will run in Jog
    Apr 2007
    atlanta, ga
    48
    Then make sure the voltage is changing at the SE1 and SE2 terminals on the drive. This is a DC drive. It requires only a Ready signal, a direction command (M03 or M04) and a speed command 0>10VDC.
    Apr 2007
    atlanta, ga
    48
    You can download manual for DL/SCZ At MEAU Download site on web
    Chard Plastic is offline Plastic
    Feb 2005
    st louis
    Talking Dl-scz
    I have a Mazak M4 also with the diarol 18.5 controller with no ready signal and no alarms and no MDI
    onedesignmachining@yahoo.com
    missouri
    Garwood is offline Stainless
    Oct 2009
    Aurora, OR
    1,267
    I have a Mazak M4 with a Fanuc 5T control I'm working at getting up right now. I'm not familiar with this machine, but I do have all the manuals and prints for it and the control. If you can tell me what to look up for you I'd be happy to help (If the 5T books would help at all).
    cwbrast is offline Plastic
    Feb 2010
    Houston,TX
    Did you get your machine working?
    I have 2 of these machines and lots of manuals, I can copy a few pages for you if you need me to. Both my machines are for sale also.
