I have a 06 Nexus 100 I am going through and doing some pm on. Couple questions, on the spindle in the maintenance book it speaks of a small hole on the bottom to check that it is clear so it can drain out.
I have found that but was wondering if it would be beneficial or risk damaging anything to remove the whole ring and clean it out good?
On the turret, it seems to be setting about .002-.0025in low using right hand tools, what is the procedure to loosen it up and relocate it?
I have done this several times on a old QT15 and it was not too bad of a job, but not sure on this one because its servo driven.
Thanks for any suggestions.
