Hi
A friend of mine recently purchased the machine listed in the title . We saw the machine power on,with random digits on the screen before purchase. Machine has been moved to his shop.
I set about to clean the 3 boards where the batteries leaked. Have replaced batteries.
Today I powered the machine up. Was met with menu and purple screen with a couple of zero's in top let corner. Could not acces the control. The screen would then cycle to random digits and back to purple screen.
I set about to initialise the control using Mazak 0989-002 Service bulletin. I managed to get the PE1/2 leds out, the PR led out on the 747 board. This gave a screen that showed the menu keys and purple screen with a couple of zero's in top let corner. Still could not acces the control.
The BT led remained lit on the FX784-8 card. Whilst trying to remedy this I found the WDAL (Check) led was lit on the FX701 card. This gave no display on screen. Ocassionally cycling power would see this led out, and a screen display, but still no acces to the control.
I have checked the voltages on the Control power supply, all are present, correct and stable. Would appreciate any assistance with this issue.
Thanks, Chris.
Thanks, Chris.
