yappiday
- Aug 17, 2011
- Black Mountain, NC
Hi! Looking for help in getting my laptop to communicate with a Mazatrol T-32.3 controller. I have been tasked with backing up the parameters off all our controllers. I am using a freeware serial communications program called CoolTerm. So far I have been successful with our 2 Fanucs, our 3 Okumas, and 1 of our 2 Mazatrols; a T Plus. But, the T-32.3 just will not cooperate. I use the same cable for all other controllers which works just fine. I am also getting communication with the T-32.3, but I am only getting the following string: q.q.q.q.q. and get a 515 alarm (CMT Mis-Connected). I have combed the 'net and have tried all options I have found. The Page 4 User Parameters on the T-32.3 are currently set as follows for DV1 (CMT):
I1 - 2 (4800 baud)
I2 - 3 (2 stop bits)
I3 - 0 (no parity)
I5 - 3 (8 data bits)
I6 - 1 (RTS/CTS)
I7 - 0 (no DC Code parity)
I8 - 0 (no wait time)
I9 - 0 (no output of DC2 or DC4)
I10 - 1 (EOB)
I11 - 0 (no CR)
I have tried recommended PC serial port settings of:
4800 baud
7 data bits
1 stop bit
even parity
hardware handshaking
I have also modified the pc and controller settings to many different combination of settings, but to no avail. Any suggestions? I am an IT worker, not a machinist, so I am working in the dark and have been relying on manuals and the forums such as this to figure these things out. Thanks!
I1 - 2 (4800 baud)
I3 - 0 (no parity)
I6 - 1 (RTS/CTS)
I10 - 1 (EOB)
I11 - 0 (no CR)
4800 baud
7 data bits
1 stop bit
even parity
