jrowland19
- Mar 31, 2018
I have a 99' Mazak SQT15msy that has been working fine with no crashes until I powered it up yesterday. Immediately after powering up the x axis was rumbling a bit and after a few seconds errored out showing some kind of controller error. I shut it down and then powered back up walking quickly around back to see what the axis was doing and looking at the motor coupling it was just kind of vibrating before it would shut down. I checked and the axis is back from the limit switch a bit also. After doing some reading, my initial feeling is a drive problem or a stuck limit switch, but before I do anything wanted to see if anyone else had seen a similar issue.
John
John
