shanghyd
- Aug 15, 2008
- San Antonio, TX
Hi all,
My machine has the error as stated in the title.
The machine won't home the Y-axis. It gives the error soft limit travel -y. The x and z home just fine.
Did a little searching in the threads and came up with several possibilites.
1. Machine might have moved when the power was off
2. Lost the parameters
The machine hasn't moved while the power was off.
We have tried changing the default parameter from -511000 to -999999 or something and still get the error.
The other solution I found was turn off the machine and turn the ballscrew until the machine is close to home and then turn the machine back on. I'll try that when I get back to work Monday.
Any other possible solutions that I might try?
