Mazak ST30ATC M/C vs ST35ATC M/C
benganboll
Hot Rolled
Feb 23, 2015
Sweden Östersund
We have a ST30ATC M/C and is thinking of replace that with a ST35ATC M/C because our ST30 only have the indexing C-axis.
Anybody know the differents between these two, they look the same exept T3 on our and T32-3 on the other.
I believe the ST35 has a slightly bigger swing but other than that, everything else is the same as the ST30. We used to have two of the ST35s.
According to the seller it has max 460mm turning diameter and that is the same as mine.
My problem is that after removing everything that cold be removed on the top of the machine I rolled it in on 2" bars and had a 1/2" clearance at the top of the machine on the port.
So it cant be any bigger if I want it inside of my current very small workshop :)
