RT Machine
- Jul 27, 2011
- Adelaide South Australia
Hi everyone,
My VQC occasionally stops with spindle lube alarm, switching m/c off and restarting clears alarm. Ive checked the filter in the lube tank under the chiller unit and it was as new - no cleaning required. Return filter in head is spotless, oil is near new and correct type, chiller fins are clean and fan operates as normal.
I disconnected the wire to the oil pressure sensor on the spindle and m/c starts normally and then after time, alarm comes on, which suggests, perhaps fault is in chiller area- any idea,s would be appreciated - cheers
