valleyduramax
- Jan 4, 2017
I have a 1997 model vtc-16B and this issue has been around since I can remember. We use mastercam x9 to do all the programming. The issue is that under certain tool paths, such as some of the dynamic paths, the machine will not feed at the programmed feed rate. If I choose an outside profile to rough a part in, the machine tops out at 87.7 in/min regardless of programmed and this is with a 0.25" dia cutter. Does the same thing on internal pockets. All I can assume is that it's machine parameter settings. Anyone ever have this issue? And what could be a fix?
Sent from my SM-A500W using Tapatalk
