Results 1 to 4 of 4
Thread: Mazatrol Cam T1
    CHANDRU is offline Plastic
    Feb 2007
    INDIA
    27
    Default Mazatrol Cam T1
    Hei Friends,
    Does Mazatrol Cam T1 Need Any Switch Settings In The Pcb's For Reinitialisation Of The Controller.
    Chandru
    Speedie's Avatar
    Speedie is offline Hot Rolled
    Feb 2009
    Midwestern MN/Wi USA
    603
    I take it this is in a lathe and you replaced the Freqrol? Did you just get it repaired or are you using a Toshiba equivalent?
    minder is offline Stainless
    Nov 2004
    Canada
    1,765
    If this is to reload parameters, there is no switch setting, there is however a 'secret' softkeys and a OP parameter for clearing memory.
    Minder.
    routlaw is offline Plastic
    Apr 2007
    atlanta, ga
    48
    I assume you have parameters saved. Turn off pwr pull battery (red & white twisted pair) from top card wait 5 minutes and replug battery and pwr on. If reloading by hand O params must be set with parity (ex: 000111003). then pwr off/on to initialize parameters.
