I need some help with a Quick Turn 15. I have owned the lathe for several years and it has been very reliable. The control malfunctioned about 4 months ago and was sent out to Mitsubishi for repair. When I installed the control and input the parameters everything worked except a few of the soft keys. Turret unclamp, gear selection, work light, machine lock. I contacted Mits and they sent out a technician. The tech stayed here 2 days and never got the machine up and running. He suggested that I call Mazak. I contacted Mazak and could never get a tech out to look at the machine. I called an independent (who used to work for Mazak and is very competent) to come out and work on the machine. He had no luck either and worked over the phone with the Mits tech to try to resolve the issue. They came to the conclusion that the ram chips must be corrupted. I purchased all new Ram chips from Mazak ($1800.00) and this made no difference. At this point the control and the front panel were sent to Mits who kept them for at least a month. After extensive testing no problems were found and the units were returned. The independent tech came back out and installed the parts again and the same problem persists. He has concluded that it must be a parameter issue. He has sent the parameters to Mits that are loaded in the control to see if they can duplicate the problem on a control at their facility. I don't hold much hope that Mits will come through as their tech , who requested to be kept in the loop on this will no longer return calls or E-mails. Does anyone have any suggestions or maybe a working Cam T2 with a set of parameters they could send me? This has been an expensive nightmare and I have lost a lot of faith in both Mazak and Mitsubishi.
