Mazatrol - t plus - qtn 20 h-p
rajesh_1355
Jan 29, 2007
india
Dear Genius ..s,
I have a favour , I have a MAZATROL QTN - 20 H-P.
It showing alarm -- 322 Rapid Mode Imp. ( ORIGIN RETURN UNF ).
As soon as mc is switched ON - normal screen flash & then above alarm appear on screen botton left corner. All other screen go blank.
Operator panel back side PCB -- 24 & 5 VDC ok but no any LED blinking / ON on PCB.
On controller -- card no. Q 141 -- only one green LED is blinking -- second upper side LED is OFF.
Pl suggest -- what can I do.
I don't have any machine parameter.
Pl help.
Regards.
Check for stuck switches on the control panel. Only time I've seen that fault is if you try to move the axis without being in home mode, IIRC.
