IronReb
Stainless
- May 26, 2011
- Shreveport/Louisiana USA
As I right this post I be damned if I can remember the control now..
Its a 1995 model QT-20 lathe with Mazatrol T plus (I think)
Tail Stock setup..
What it the proper way to setup the TS.
Currently, I move the body to a position that lets the TS spindle extend about 3" or so, in the setup page I tell it that amount.
I'm guessing there is an Mcode that would extend-retrack if I were doing production?
So far I don't have issues but if I ever try to run a large bull nose center I am afraid the current tool path will rapid into a larger
center diameter.
How do you control the rapid movements?
Would love to rapid X then Z in some cases.
Offset pages and tool wear comp....
For some reason if I hit the button under the monitor (tool offset) and change the values it seems to have no effect on the actual part size.
To control tool wear or dial in to size I have to go to the geometry page and offset X there, this works but what I don't like is if say the diameter
programed is 1.5000 and I have offset X-.005 to get it to actual cut 1.5000 in the position screen it shows 1.4950, would love to be able to set tool correctly so when position screen says 1.500 it IS 1.500
Machine has a tool probe, currently I only use it to set Z, when used to set X its about .0450" off actual cut size.
So I do a test cut, mic cut, go to tool offset geometry page, cursor to correct tool, TEACH and input actual diameter that I just cut.
What is the proper way to setup the tools in this machine? I do understand the tool data page and have that part under control.
Thanks for your feed back.
Iron
Tail Stock setup..
center diameter.
Iron
