Results 1 to 13 of 13
    Dsnyder is offline Plastic
    Aug 2006
    Redding,Ca
    16
    Post
    I am getting ready to replace batteries in a QT-8. How do you save a copy of parameters for back-up?
    D. Rey is offline Titanium
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    couple ways to do it that I'm aware of.
    Write them all down and enter them by hand if you lose them.
    There are caps on the boards that will give you a few minutes to change batteries. Just exactly how long I don't know. I switched mine out in under 4-5 min and did not lose parameters.
    Get software like camlink that allows you to save CMT info, mazatrol programs. download to disk or HDD.
    Aug 2006
    Redding,Ca
    16
    Post
    I am not familiar with camlink, am using PC-DNC PLUS to send/recieve files. What is the trick to exporting the data?
    Aug 2006
    Redding,Ca
    16
    Post
    sorry, the control is t-2
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    I don't know if a DNC program will allow backup of mazak parameters as it is stored as a CMT file, mazak proprietary stuff. That's why you need dedicated software.
    Try it though, nothing to lose.
    Just go into the data I/O menu on that T2 and check parameters, then upload.
    Aug 2006
    Redding,Ca
    16
    Post
    I broke down and found a pencil. Thanks for the help
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    LOL, yep that may be the most reliable and cheapest way in the end.
    WKN
    WKN is offline Plastic
    Jun 2006
    21
    Post
    I run a 1986 QT10 with a T1. I have changed the batteries out several times in the past. All I do is turn the machine on and then replace the batteries and then leave the machine on for 24 hours after that so the new batteries can charge up. I also have a copy of the paramaters on paper just in case. I have never lost any parameters doing this type of batterie swap.
    vantim is offline Plastic
    Jul 2006
    Willoughby Ohio
    44
    Post
    WKN you took the words right out of my mouth. Leave the machine on when changing them. LOL
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    So you can pull the control boards without damage to them with power on?
  11. #11
    WKN
    Jun 2006
    21
    Post
    Nervis I don't know about pulling the complete board. My batteries have a pig tail on them that actualy plugs into the board.
  12. #12
    Jan 2003
    Phoenix, AZ
    2,095
    Post
    Ah that makes sense. Mine are bolted to the boards and sandwiched between other boards, no way to get em out without pulling the board they are on.
  13. #13
    Up 'n Adam is offline Junior Member
    Aug 2006
    Maine
    Post
    most controls will allow you to pull mem board to remove any hardware holding batts BUT DONOT disconect battery until you plug board back in and turn on machine. again be sure to back up parameters,macros programs offsets ect. saves a lot of heartache. This info only works if your battery has enough juice to keep mem with board out
