Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By SteelCutter
Thread: process question
    PHDesigns is offline Hot Rolled
    Jan 2002
    Oklahoma, USA
    520
    Default process question
    Ok, just when I think I am beginning to like this thing.........well, any way, trying to run a pattern. Basically hose barb type stuff. Use the groove option, pitch, # of grooves and it draws the shape and all great. But when I go to run, wanting to turn it with a left hand vnmg tool, it gives me an alarm for illegal tool width. I guess it is looking for a grooving tool to match the width. Shirley I am not going to have to plug in each 'barb' individually for it to work. (Oh yeah, QT28 w/M32-2)
    qwikturnin is offline Aluminum
    Toronto,Canada
    66
    Yes use a vnmg insert but use bar out to describe the profile.
    You cannot use a turning tool in a grooving process.
    Robert
    Jan 2002
    Oklahoma, USA
    520
    SO if I got 20 of these on the part, I have to write a line for each one!?
    cnctoolcat's Avatar
    cnctoolcat is offline Titanium
    Sep 2006
    Abingdon, VA
    2,015
    Mazatrol is easy to copy lines. 20 lines of geometry in a unit aint too bad...
    SteelCutter's Avatar
    SteelCutter is offline Hot Rolled
    Oct 2006
    The Land Of Lincoln, where the air still smells fresh (SOME PLACES TOO FRESH)
    588
    Lie to the machine, IE: describe your turning tool as a grooving tool.
    *Been there, done that!
    Philabuster likes this.
    Jan 2002
    Oklahoma, USA
    520
    Quote Originally Posted by SteelCutter View Post
    Went there tried that, didn't work. At least the way I tried.
    Philabuster's Avatar
    Philabuster is online now Stainless
    Jul 2006
    Tempe, AZ
    1,700
    Quote Originally Posted by PHDesigns View Post
    Alarm will occur if 'groove tool' , aka vnmg, is described too wide. Also, make sure radius on groove tool description 1/2 of described tool width or less. Machine is ok with full radius groove tools (.062 wide with .031R), but will throw error if radius exceeds 1/2 tool width (.062 wide with .0312R).
    Mike_ is offline Aluminum
    Dec 2010
    Kansas City KS
    235
    Write it as a subprogram with a shift 20 times, quickest and easiest way I can think of. Much easier than copying and adjusting 20 lines of program should you need to make changes.
    If your groover width is wider than the groove width minus whatever you entered for a finish allowance you will see that alarm too. Unless you leave the rough groove tool out, but I can't see that boding well for the life of your tooling.
