So i got just sick enough of the junk coolant delivery setup (whilst burning through inserts cutting 304 because the line kept moving) that I made a solution.
Copied from the plate described earlier (i'm sure there was a photo somewhere too...)
It routes the coolant to both sides of the tool holder right at the tip, also routes it to the face (mainly because i had to drill there for the internal routing, but could be usefull) All holes are 1/8 bsp threaded for either blanking (i've got some 1/8bsp grub screws on the way to blank it flush) or for simple cheap 90/45* elbows.
As you can see it smashes out a ton of coolant at a good pressure just using a m-m 90 elbow.
I've only made 1 so far, but if anyone is interested i'll be making myself another 3 and am happy to pump some out for others if they're interested. Alternately i can hook you up with the CAD/CAM for it as well.
Cheers,
Trav
