Tool eye issue Mpx 620-T32-6
mrcompletely
Jan 26, 2009
I am having a tool eye problem on a Multiplex, hopefully someone has seen this before. When you go to the tool data page and press the Tool eye ON, you get nothing (yes it is in handle mode). If you pull the tool eye down the Tool eye OFF lighted button flashes, then you get a measuring sensor alarm after a few seconds. When you push the ON and pull the eye down you don't get the airblast or anything. I removed the cover on the motor and the proximity switched for UP and Down are working. No relays on the relay panel are doing anything, unlike on the other head, when several of the relays make or break when the tool eye is turned on. Any ideas, please??
