We are getting a periodic fault #13 on the x axis. The drive LEDs are indicating an over current situation when the fault happens. The fault does not appear to be related to machine position, sometimes it can be sitting idle and go into fault mode.
I am told the suspects are the wiring, the motor, or the drive.
There are 4 wires at the motor in addition to the two multi pin connectors. They are labeled IG1, IG2, A and B. These four connect with the drive. Excuse my embarrassing ignorance of this, but I thought this would be a three phase motor with 3 equivalent wires. That does not appear to be the case.
Where should I begin the diagnosis? Is an insulation problem on the wiring a likely suspect? There seems to be a fair amount of coolant that makes its way back there, maybe that hardened up the insulation and is allowing a short?
After testing the wires, would attempting to isolate the problem by switching the output wires between X and Z be a good idea? The drives are the same (I think).
I bought a 1000v meg ohm tester to diagnose the motor if it comes to that. I know to disconnect the power and all connections to the motor before testing it to avoid frying something up the line. If I do that and ground the black wire on the motor (anywhere on the motor chassis?), can I apply the tester to wires A and B (i am assuming these are the primary conductors since they are larger than the IG wires) to check the windings? Is that all there is to it? I somehow doubt the motor itself is the problem since this machine is not in constant use. I thought it might be a good idea to check the brushes while I'm in there and maybe get a can of clean air to blow out the holes and any carbon that may have accumulated in there. In my (limited) experience, drive amplifiers are more fragile and likely to have a problem than the motor. I have no evidence to support that in this case, however.
Thanks to all for reading and sharing your thoughts.
