If the top 2 LED's are lit, please verify that there are 2 below the lit ones that are not lit. It is very common to give a quick look and actually be looking down so the middle 2 lit LED's appear to be the top two.
The top 2 lit is IOC fault
The middle 2 lit is external emergency stop.
With the data we have, it could be either one, both will give the 20 nmi emergency stop. The troubleshooting method is not the same for both alarms.
I have been called a couple of times to fix the IOC fault and is really an external emergency stop problem .
If it is an IOC alarm, It is wise to explore several things first so you won't damage it again, after the repair.
1. Insuring that the transformer is set to the correct taps as Philabuster advises in posts #2 and 5 and my advice of measuring the voltage at the input to the FR-SE in post #3, this also makes sure all phases are there and at the proper voltage.
Post measurements. We can guide you thru the tests.
2. Insuring that the phase rotation LED is lit as pictured in post #5. It may or may not run if this LED is out, depending on the drive parameters. It should always be lit.
These conditions can cause early failures of the FR-SE.
Other conditions that should be checked is the power supply outputs before removing the unit for repair. A single one missing, even intermittently, can, over time cause a transistor failure that gives an IOC fault.
If one or more is observed as missing, the power supply needs to be repaired or replaced as part of any repair that replaces the failed transistor. This can save future repairs that seem to just make it past the warranty period.
If it is an external emergency stop fault, there is a lot of checking needed to determine what is causing it.
Where in PA are you? I will be near Brookville mid next week.
Bill
