Andrew M.
- Jan 16, 2006
- Atlanta , GA
Here we go again, the old QT15 got me cornered once more ... The low battery alarm which i had seen recently , but always cleared up after few minutes of powering ON , finally turned into a "parity error" right when i replaced the batteries .
Re-installed the parameters by hand (Most, not all), cleared all the corrupted pages, dumped tool setup, chuck, material, programs and pretty much all the pages that showed **** **** , cleaned all up ( I think )
Re-initialized the memory by turning On the second switch on FX701 powering up for few minutes and than returning it back to the original setting. The memory parity error cleared , the control came on but i still have few issues that got me brain-dead ...
The X axis is very sluggish even with the hand wheel it appear to have a delay in responding ... On the parameter page as i mentioned, some of the parameters are not allowing any change , this are the K49 to K96 , They all were Zero now they have all kind of mostly negative numbers and I can`t change them ! Also on parameter page 1 there are some values on the "C" axis column that cannot be turned to Zero ( MC and LP ) and i do not even have the C axis
I know I`m doing something wrong , but I can`t put my finger on it ( wrong initialization procedure ? Hidden parameters? protected parameters? ) and today this big blue box got the best of me. If somebody has a hint or a suggestion or something, anything, please throw it at me, tomorrow i will try again
Thank You in advance
A.M.
A.M.
