michaelthomas
Cast Iron
- Aug 15, 2012
- Montrose, CO
Hello, I have been seriously enjoying my QT20n......but with the onset of the really hot weather (100 or so) I have been getting a Zaxis Drive alarm.
Everything will work fine in the morning, but once the temp gets over 95ish I will get the drive alarm.
It is the 4th LED down on the TRA 41a drive. The book says it is a fin overheat alarm and will disable the drive at 80 (180F) degrees C and reenable at 55C (130F). I am a very light user of the machine, and there is no way its getting that hot.
I got the error this afternoon, and just went home. I came back a few hours later, and the machine had cleared the alarm. I finished running one part for about 3 minutes, then spent the next 15 minutes writing a new program. Just as i finished the program, I got the alarm again.
I immediately pulled out the drive, and could feel no heat above ambient on the heat sink. It was about 97 degrees at that time.
I see a device on the heat sink that is probably the temperature sensor. It changes resistance when I put a hair dryer on the heat sink. I guess it's a type of thermistor. Seems to range between 54 and 59ohms when heated.
The alarm was Z Drive Axis 14, I believe.
Just wondering if anyone has dealt with this before?
Some time tomorrow, I suppose I will check the resistance on the x drive to compare.
Its definitely not shutting off because of excessive heat generated by the drive itself, as it's probably not over ambient by more than 10. degrees F.
Mike
Mike
