reduce cutting depth mazak lathe
Results 1 to 9 of 9
    Feb 2009
    Janesville, Wi
    22
    Default reduce cutting depth mazak lathe
    I'm trying to reduce the depth of cut on X as I
    rough in a diameter
    Oct 2008
    Connecticut
    80
    Default not possible in mazatrol
    The radial DOC per pass for roughing is a constant number and cannot be decreased to a min as multiple passes are performed.
    I think USER MACRO B in EIA and some real good programming could get you where you want to go.
    Same end might be possible with EIA and CAM system?
    -90% Jimmy
    Feb 2009
    Janesville, Wi
    22
    Default Thanks for th response
    I will take a look at the .eia possabilities.....
    Sep 2006
    Abingdon, VA
    3,107
    3925
    2478
    Actually, there is a parameter that allows the DOC to decrease for each pass. Look in your Mazatrol manual.
    Feb 2009
    Janesville, Wi
    22
    Default Toolcat... (mazatrol decrease)
    Thanks for the reply.. but I am having a hard time finding it. our control is a 640t Nexus... Have you been able to do this with mazatrol programming?
    Thanks again...
    Oct 2008
    Connecticut
    80
    Default K1 parameter from the book
    This is a cut and paste from a Fusion T parameter manual:
    K1 = Cut depth reduction rate for rough cutting
    in bar machining unit (BAR)
    Cut depth can be reduced as remaining workpiece thickness becomes
    less in rough cutting in bar machining unit (BAR). Reduced cut depth (A)
    can be expressed by
    A = T ×K1/100
    where T=Remaining thickness (radial value).
    Note:
    Up to 100 % can be set.
    VERY GOOD WORK, CNCTOOLKAT!
    Looks like this could achieve the goal! It also looks like some test programs and tool path checking will be needed to verify and master this K1 parameter!
    I have NEVER USED THIS and I sure hope it works for you!
    -90% Jimmy
    Part of the fun of Mazatrolling is to uncover these gems of capability and make them work! I also think the first guy that converts "jinglish" cnc manuals into colloquial American english will become a millionaire!
    Feb 2009
    Janesville, Wi
    22
    Default thanks again
    I will give it a try next week... I will post the results...
    Feb 2009
    Janesville, Wi
    22
    Default didnt work...
    Thanks for the help.. maybe the Fusion 640T nexus doesn't allow this in mazatrol programming...
    Nov 2006
    Jupiter, Florida
    232
    83
    7
    Rats. I just tried it too, after reading PDM's post. Didn't work for me either. I also have a 640T Nexus control.
    Tried K1 in both TPC and in the parameters.
    K33 and K34 don't work in TPC but they do in the parameters so I was hoping.
    No luck.
