Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Specific Machine Forums > Mazak
Mazak Mazak CNC machines and control discussions
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 02-08-2010, 07:03 AM
Default SQT-15 hydraulic issues
I've noticed coolant is getting into the hydraulic unit from somewhere. Has anyone had this problem. Possibly a seal on the chuck?
  #2 (permalink)
Old 02-08-2010, 10:32 AM
Cast Iron
If I remember correctly, that's exactly what it is, although what I can't remember is if MAZAK has a return tube for excess hydraulic fluid that could also be getting contaminated, but I don't think so. Most likely an o-ring in the spindle/chuck.
  #3 (permalink)
Old 02-08-2010, 09:31 PM
The two places that coolant and hyd are close to each other are in/on the turret, and the power chuck accuator. 99% of the time it is just a p-10 o-ring on the cooland block on the turret. Very easy to fix on some turrets a little harder on others. Depends on if the coolant piston is behind the turret (remove turret to fix) or mounted next to the turret.
Justin Terry
  #4 (permalink)
Old 02-09-2010, 04:34 AM
Titanium
yup........
also some machiones on top the hyd tank is a tube from the pump this could be dislodged letting stuff on top the tank get in
but my first thought would be the coolant block although
what mine usualy does is drain the hyd oil into the coolant not visa-versa
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
