I pulled the coolant block off so we could remake the brass piston out of 316ss in prep for a 1000psi unit I have waiting.
The new part is made and I just got to wondering over the weekend, is there just the one brass part in there that needs remade?
I'm not fully sure how this block works. I pulled the plastic/rubber/whatever it is seal off the snout of the brass piece and then just pulled the brass piece out of the block. Didn't see any springs or anything.
Measured up the piece and had it remade.
The o-rings and turret seal look to be in good condition. Are these items that should be replaced? I didn't see any chips or debris in the block or in any of the lines. Previous to disassembly the coolant flow was pretty reasonable.
How exactly does this system work?
Are there any exploded diagrams anywhere (I haven't run across any)
Thanks!
Thanks!
