gmc1724
- Oct 24, 2013
- United Kingdom
After 18 months of searching for a replacement for my QT15 that went out with a bang I've finally found something in my budget, a SQT18MS. The used market in the UK for Mazaks in the sub £20k area is all but non existent and I have plans to retire in 4 yrs time so throwing £40k at a machine just wouldn't make sense so I've ended up with this sub spindle machine. I've never used a sub spindle before, is the b-axis soley used to "pick" off from the main spindle and then homed to use the turret z-axis for turning? Is it common to use the sub-spindle as a 2nd lathe if you wanted to run two different parts on one machine? I'm thinking more of if I wanted to leave a long running job on the main spindle and use the sub for some small jobs in between.
