Hi guys,
The machine has a servo controlled tailstock in W-axes.
I am programing the tailsotck and i don´t know how to move the tailstock to an especific position without pressing the piece. I write G0W100 in MDI and the tailstock does not move. I know how to move the tailstock with the M741, M742 and M743 codes, but in this work i don´t want press the piece. I need use it like a stopper, pullout the bar, press the piece manualy and then run the program.
The other problem is refered to the tailstock speed movements.
I am doing others works that requires the use of tailstock but in manual mode. For example, when you need to machine a shaft between centers.
When the door is opened and the key is in "0" position the tailstock movements are limited to 149,3 mm/min. Obviously it is a paremeters problem, but i have read the parameters list and don´t see where it is.
Can somebody help me?
Thank you!!
Thank you!!
