asticx
- Jul 14, 2011
- Saskatoon, Canada
Some curious threading questions..
If I am cutting a 60 degree thread and I have 60 as my angle of thread will it just plunge cut... if I set it as 29.5 degrees it will just cut on the one flank? Is there a way to get it so it 'zig-zags?' .. I know there is on another machine I run.. not sure about mazatrol.
Also for threading types you can select multiple numbers.. ie 0 is standard .. 1 is constant depth.. 2 is constant area.. what is the most common you guys use. I usually use #2 just curious which one is preferred and why.
Thanks in advance for any replies.
Danny
Danny
