Use Tailstock On Mazak QT Nexus 200 With No Thrust Applied To Work Piece
Results 1 to 8 of 8
    Sep 2014
    Georgia
    191
    190
    86
    Default Use Tailstock On Mazak QT Nexus 200 With No Thrust Applied To Work Piece
    It is a Japanese made QTN 200 model from the early 2000's. I did not get the EIA/ISO option.
    I would like to machine some delicate Teflon parts that have a central 3mm hole. I plan to use a hardened and polished rod as a dead center in the hole's entrance. It's important that the tailstock not apply any thrust, though.
    Is it possible to set the tailstock to work this way with code or with a changed parameter?
    Edit: I wonder if I could use 'Set Home Position' to help out some way?
    Thanks!
    David_M
    Jan 2013
    Plainfield, Indiana, USA
    1,473
    1096
    751
    I am hoping you get some help with this. I too need to use a tailstock with extremely low thrust setting.
    GL!
    Apr 2010
    Wisconsin
    5,227
    3894
    2886
    Under the MAINT page soft key options you should see one for TAIL or TAIL THRUST ( can't recall right now ) Once, in there, you will see 5 or six options for thrust pressure. Use the lightest one, on the left. All the set point function does is tell the machine to throw an hissy fit ( alarm ) if the center travels past that point by a certain amount.
  4. Likes David_M liked this post
    Sep 2014
    Georgia
    191
    190
    86
    Quote Originally Posted by Zahnrad Kopf View Post
    Hey Zahnrad,
    The lowest is 1kn (225 pounds) . I'm working with Teflon that is .5" diameter and the thrust crushes it.
    What I'm thinking about is to give the tailstock a new home position that is much closer to the chuck. Then use a 1/2" MT5 end mill holder in the tailstock with an ER11 straight shank collet chuck gripping a 3mm dowel pin (this slides freely in the end mill holder for room to change parts). After putting the Teflon part loosely in pie jaws, I would slide the collet chuck's dowel pin into the 3mm drilled hole of the part, then lock it in its new position in the end mill holder (if any of this makes sense).
    Best regards,
    David
    Sep 2014
    Georgia
    191
    190
    86
    I found a solution.
    In a nutshell I changed R-97 (R-97 sets the value for the far left tailstock pressure selection) to a value of 1. That makes it give the confirm beep without the tailstock moving.
    Using an MNP unit:
    732 to set pressure to second value
    742 move to second tail position. this is where it needs to be to support fragile part on the pin.
    731 set tail pressure to the first selection
    741 move tail to position 1 (position 1 is set 1" closer to chuck than position 2). tail won't move because of R-97 setting, but you get the conformation beep and program runs without error message.
    732 set to second pressure value (if you use the arrow keys to move the tailstock manually it will move as expected)
    Tailstock has to be sent to its home position before you can run this again.
    MNP
    M05
    M09
    M32
  7. Likes Zahnrad Kopf, edge22, cnctoolcat, Joe788 liked this post
  8. #6
    Apr 2010
    Wisconsin
    5,227
    3894
    2886
    Nice. Good work!
  9. #7
    Jun 2013
    Oregon
    943
    223
    529
    Outstanding!:
  10. #8
    Sep 2014
    Georgia
    191
    190
    86
    Just a follow up.
    The job went well with changes:
    Using an MNP unit:
    M05 //Stop Spindle
    M09 //Stop Coolant
    732 //Set to a value other than 731
    742 //Move to second tailstock position. This is where it needs to be to support fragile part on the pin.
    731 //Set tailstock pressure to the first selection (This is the one that has been changed to 0 for parameter R-97)
    741 //Move tailstock to position 1 (Position 1 is set .040" farther from the chuck than position 2 (A less negative number)). Tailstock won't move because of R-97 setting, but you get the conformation beep and program runs without error message.
    732 //Set to a value other than 731 (If you use the arrow keys to move the tailstock manually, it will move as expected)
  11. Likes Captdave, Zahnrad Kopf liked this post
