Captdave
Titanium
- Sep 24, 2006
- Atlanta, GA
I need to use that tail stock on a couple of shafts 5/8 6061 shafts 8" OAL and have a couple of questions...
My plan is to do facing, center spot and a small amount of OD profiling to provide clearance for the live center, M01, the pull the stock by hand to touch the center, extend the center, then finish the profile and part off to length.
1. My live center is MT3 so picked up a MT3 to MT4 adapter sleeve. Tried a test fit but the tang prevents it from going all the way in. Just grind it off?
2. This maybe a silly question but how do you remove the center when finished?
3. Never using a hydraulic tailstock before, what would be a good pressure to start with to hold the part but still allow it to be cut off without binding the parting tool?
Any tips or suggestions are all ways appreciated.
