VQC 20/50 axis drive adjustment
Community On The Web
Results 1 to 8 of 8
    Apr 2013
    South Australia
    244
    66
    101
    Default VQC 20/50 axis drive adjustment
    G'day all,
    does anyone have the procedure for adjusting the TRA31/41 drives. I have some information on the drives and what the adjustable resistors do but It doesn't tell you the sequence of adjustments. I know that the droop has to be zero and the gain 33 @1000p/m but when I set to that the table shakes so am guessing that some of the others need to be adjusted first to correct this.
    Thanks for any help
    Cheers Bob
    Sep 2005
    il.
    6,501
    29
    1135
    set those numbers while someone is moving the table in rapid 10%
    Apr 2013
    South Australia
    244
    66
    101
    AAhhhh that might be why i'm having problems. I was setting the droop while stationary then setting the gain and moving the table to check. I will try that today thanks mate.
    Quote Originally Posted by wippin' boy View Post
    Sep 2005
    il.
    6,501
    29
    1135
    now that you say it the droop may be while sitting still.
    been a while
    Apr 2013
    South Australia
    244
    66
    101
    Well I tried it while moving and it is better but the setting is not stable. It fluctuates up and down considerably so that its impossible to tell the actual setting. It must be one of the other resistors that need a touch up to stabalise the setting. Might have another play today and see what I find. Can't make it any worse lol.
    been a while
    Sep 2005
    il.
    6,501
    29
    1135
    the droop does bounce around a point or two
    if it won't hold settings the drive might be less than desirable
    Sep 2005
    il.
    6,501
    29
    1135
    the gain is set while making a slow rapid move and is usually rock solid
    Apr 2013
    South Australia
    244
    66
    101
    This bounces a bit. That's why I think that something else needs adjusting in some sort of sequence but the information I have tells me not much
