Results 1 to 3 of 3
    Empireweld's Avatar
    Empireweld is offline Aluminum
    Feb 2007
    Cucamonga, Ca. USA
    210
    Default VQC hydraulic counterbalance
    Does anyone have any experience with the counterbalance? I can't find a valve in the
    manuals that would control the cylinder. I think that the cylinder walls may have become
    polished/damaged allowing fluid to bypass and creating an excessive load on the z servo.
    Leelund is offline Aluminum
    Mar 2008
    Northern Kentucky
    133
    Under the front Z axis cover in front of spindle motor. Three valve stack- co bal valve is center with a gauge block and gauge installed. If blow by is happening you should have a hydraulic leak from the breather installed in the bottom of the cylinder. Also tank level will be dropping.
    Mark McGrath is offline Titanium
    Mar 2002
    Scotland
    3,945
    It`s in the maintenance manual.Gives setting procedure and pressure.
