Results 1 to 13 of 13
    David Carlisi is offline Stainless
    Nov 2007
    Alpharetta, Ga USA
    1,465
    Default VTC-16 Error Message 209
    Error message 209 is Slideway Oil Constant. This started at the end of last week. First, 2 or 3 times per day, but today, already 5 or 6 times. No strange noises from the machine, everything else working properly. When the way lube is pumped manually 4 or 5 times, the error message can be cleared, and the machine re-started. I already checked the power going to the way lube reservoir, it's hot. Any suggestions what I should check next?
    Nov 2007
    Alpharetta, Ga USA
    1,465
    I called Mazak tech. support, spoke to Dennis. He said to check to make sure the motor on the pump was functioning, and the plunger was indexing every 6 minutes or so, and it is. The problem must be elsewhere. Maybe a sensor?
    Justin_Terry is offline Aluminum
    May 2009
    The Woodlands, Tx
    178
    have you check the pressure switch, or float switch if it has one
    Nov 2007
    Alpharetta, Ga USA
    1,465
    It does have a pressure switch, but the reason that I don't think it's the problem is because if you pump it manually 3 or 4 times, you can re-set it. Maybe the pressure IS too low, and I just need to buy a new pump? Is there a way to check the pressure?
    May 2009
    The Woodlands, Tx
    178
    have you checked to make sure that the filter on the bottom of the pump isn't cloged. seen that many times.
    Tonytn36 is offline Diamond
    Dec 2007
    Southeastern US
    4,286
    Check your lines for breakage. If no breakage, highly suspect the pressure switch. We've replaced a ton of those things for that exact problem. I don't know the detail failure mode, but it acts like it gets too stiff over time and will start tripping out under normal pump operation. When you pump the plunger by hand, you overpressure the system vs. what it normally sees, switch makes, all is good......until the pressure bleeds back off.
    Nov 2007
    Alpharetta, Ga USA
    1,465
    Quote Originally Posted by Justin_Terry View Post
    I just dis-assembled the pump and filters, cleaned and re-installed. Same problem. My next step will be the switch.
    Nov 2007
    Alpharetta, Ga USA
    1,465
    I removed the switch and put a pipe plug in it's place, and the machine is running error free. The switch is $108 from Mazak. By process of elimination, that must be the problem. I took the switch apart, but other than the spring and the screw that holds the spring, the remainder of the switch can not be dis-assembled without destroying it (as far as I can tell).
    Thanks to Justin_Terry and Tonytn36 for the help.
    David
    Leelund is offline Aluminum
    Mar 2008
    Northern Kentucky
    133
    David,
    You removed the switch and installed a pipe plug, and the machine is not throwing 209 alarm? Uhh?????
    Nov 2007
    Alpharetta, Ga USA
    1,465
    Quote Originally Posted by Leelund View Post
    David,
    That is correct. The wires are hanging in mid air waiting for the new switch. Why? Should it register an alarm? It's running like a new one right now.
  11. #11
    Mar 2008
    Northern Kentucky
    133
    Huh, Just make sure you are still using oil from the lube tank until it the new one arrives.
  12. #12
    Nov 2007
    Alpharetta, Ga USA
    1,465
    I'm watching it like a hawk. The pump is working properly, and way lube consumption is normal, more or less 8-10 ounces per 10 hour day (estimate). Everything is functioning properly, except that there is no switch to tell us if the pump does fail, or the reservoir were to run out.
  13. #13
    cnctoolcat's Avatar
    cnctoolcat is offline Titanium
    Sep 2006
    Abingdon, VA
    2,015
    If the 2 wires are not touching on the ends, and the machine is running fine, then the pressure switch must be a normally open (NO) type. When the pressure falls, the NO switch will close (and thus "connect" the two wires), and the machine will give the alarm.
