Tim Osborne
- Sep 8, 2005
- UK
Hopefully someone can help with what should be a simple programming problem with our Mazak QT10 with Mazatrol T Plus.
We've used Fanuc/Yasnac controlled turning centres for years but recently bought a used QT10 for some simple parts we need to make. So we are complete novices in Mazatrol, and we are struggling somewhat.
So, the problem:
Family of parts, some of which are from hexagon stock. These I wish to chamfer the part off face of the component at 30 degrees.
Chamfering at 45 degrees is easy enough. Select a 'Groove' process, type 4, and define the chamfer size in the sequence definition.
But how do you do something other that 45 degree? Note we want to use the parts catcher (if that makes any difference)
Tried various groove types and tool moves but not had any success. I'm sure, like most things, it is easy when you know how!
So, the problem:
