Never seen it done. Bet the coders know though. Probably too big a deal to tweak the TMU macro and figure offsets from centerline for each tool. Probably have to tie the tool data in somehow. You 'd think that with todays control that it would. Small diameter emills should be no problem though- up to the plunger center pad diameter.
if you are not using a plunger style presetter you can measure both l. and d. of any tool using special menu feature press menue select key twice select special menu select either length or length plus dia. tool num. tool dia. cycle start spindle turns on rev. will offset to measure length and then move to measure dia. have to be in memory to run this
