gjrepesh
Cast Iron
- Aug 30, 2002
- Royse City, TX
I am preparing the concrete floor in my shop for painting...epoxy. I have two issues to address. The finish on about 1/3 was not very flat or smooth in places. I rented a floor grinder and have this section much flatter and smoother. The process did remove some of the stones from the concrete so there are divots that I would like to fill. Any recommendations on what would be a good product to fill these in? I was thinking some kind of two part epoxy or maybe a product that I used on larger problems called Rapid Set Cement All. It seems to adhere to the existing concrete quite well but I don't know about small areas like the stone holes.
Also I have some surface crack in the concrete. I am thinking of using a diamond disc to open the crack up and use the Rapid Set Cement All to fill in. I don't want to go too deep...maybe and inch. Any thoughts or comments on this?
After the repair is done I plan to rent the grinder again.
I would appreciate hearing from anyone who has done this type of concrete repair and what you recommend. Thanks. Gary R.
