Results 1 to 2 of 2
    PracticalMan is offline Super Moderator
    May 2009
    353
    Default Sodick to Feature Advanced Linear Motor Driven Technology at IMTS Booth E-5102
    Sodick, Inc., will be featuring its latest innovative technology, new warranty programs, consumables and various contests and prizes at IMTS 2012 in booth E-5102. Sodick will be introducing its new 7 year machine warranty program, SodickCare Premier. SodickCare Premier is Sodick’s “everything included” warranty program. This program includes many more benefits then a standard machine warranty and can be extended for up to 7 years of full coverage. Another new program Sodick will be showing is AfterCare. AfterCare is a 1 or 2 year used machine warranty. AfterCare allows for a Sodick, Linear Motor Driven, used EDM to be under warranty for up to 10 years. Stop by the Support Center in the Sodick booth to learn more about this unique program. Sodick, Inc. will be displaying a multitude of machines at this year’s IMTS to show a large variance in size and technology. Five Wire EDM models will be on display including the AP250L, VZ300L, AG400L, AG600LH and the AQ750LH. Three Sinker EDM models will be featured in the booth including the AD25L, AG60L and AG80L. Two High Speed Vertical Mills will be in the booth including the HS650L and TT1-400A.
    The AP250L is a Fine Wire EDM that maximizes cutting efficiency. The AP250L is used to EDM small intricate precision parts that require a micro wire diameter. The AP250L will be demonstrating .001” Wire, cutting in oil dielectric using Eco-Cut O Technology, which enables the AP250L to cut 25% faster than previous oil models, and 12% faster than water with a finer surface finish. The VZ300L Wire EDM is Sodick’s cost-friendly option. The machine achieves outstanding levels of accuracy and cutting speeds comparable to high end Sodick EDM models. The AG Series WEDMs are a precision machining solution that have the ideal combination of speed and accuracy. The AG400L is ideal for small to medium sized parts and molds that require close tolerances and fine surface finishes. The AG600LH features a 20” Z-height allowing a unique height for its size. The AG600LH will have an integrated A/B Table and will be displaying 6-axis machining. The AQ750LH is from the AQ Series of Wire EDMs, which is Sodick’s line of large capacity and extreme taper Wire EDMs. The AQ750LH features a fixed table design which allows for a workpiece with greater weight to be machined without affecting the table positioning or workpiece accuracy. This machine will be showing a new software feature for gathering machine data, an ideal solution for the aerospace and die/mold industries. All Sodick Wire EDMs are Linear Motor Driven and feature a 10-year Positioning Accuracy Guarantee.
    The AD25L is Sodick’s compact Sinker EDM. The AD25L is a cost-friendly, high speed, small footprint linear motor driven EDM. Two of the AG Series Sinker EDMs will be on display in the booth. The AG60L will be displayed along with a robot to show the ease of automation for this line of machines. The large capacity AG80L linear motor EDM will display the high performance of this series of machines. The AG Series is ideal for medium to large sized aerospace, energy related parts, die/molds that require close tolerances, fine surface finishes and deep rib machining. The AG Series has a simplified control mechanism which provides a direct link between the drive and the control. This ensures the fastest possible servo response time and optimal spark gaps at all times. These machines also feature linear motor drives and a 10-year Positioning Accuracy Guarantee.
    Sodick will also feature two of its High Speed Mills at IMTS. The HS650L includes a linear motor drive system, 40,000 rpm spindle. The HS Series is a highly rigid, robust machine capable of withstanding the rapid acceleration and deceleration generated by linear motors allowing for a wide range of high-quality finish, complex machining. During the show, the HS650L will demonstrate graphite and hard metal machining. The new TT1-400A has unique construction coupled together with linear motor drives and a 40,000 rpm spindle.
    Sodick Hightech EDM Consumables will be on display in the Sodick booth. Come learn why choosing the right consumables for your EDM is so important to maintaining the life of your EDM. While you are there, Sodick Hightech EDM Consumables will be holding a contest and raffling off prizes. So stop by to win.
    Sodick Inc., established in 1976, has sold over 55,000 EDMs worldwide and has had over 30,000 linear motor EDM deliveries. Sodick machines are used for the production of dies and molds as well as other various applications that cannot be produced by standard machining methods. Sodick has four ISO certified manufacturing facilities with over 3,100 employees worldwide and technical centers located in Chicago, New Jersey and California. Sodick offers the industry’s first 10-year Positioning Accuracy Guarantee on all of its linear motor driven EDMs.
    For more information contact:
    Sodick, Inc.
    1605 N. Penny Lane
    Schaumburg, IL 60173
    847-310-9000
    info@sodick.com
    Sodick | EDM | Wire EDM | Sinker EDM | High Speed Milling
    edmmachine is offline Plastic
    Dec 2012
    USA
    CNC Wire Cut Electrical Discharge Machining, first found by former Soviet Union scientist in middle of 20th century, is one of widely used machining methods today. There are two different wire EDM existing now in global market. Fast feed wire cut EDM and slow feed wire cut EDM, fast feed wire cut EDM was developed by Suzhou Changfeng Mechanical Factory in 1970’s, nowadays, Suzhou is the major base of fast feed wire cut EDM machine. Main difference between fast feed wire cut EDM and low feed wire cut EDM: 1) former one use usually uses molybdenum wire as electrode, latter one uses brass wire; 2) former one uses saponification working liquid; latter one uses deionized water; 3) wire feed speed of former one is around 11 meters/second, while 3-5 meters/minutes of later one; 4) molybdenum wire is used repeat continuously until it brake; oppositely, brass wire is used for only once; 5) cutting accuracy and surface finish of latter is better than former; 6) price and using cost of former one is much lower than latter one.
    Today, as fast feed CNC wire cut EDM is original from China, there are a lot of manufacturers of fast feed wire cut EDM in China, Suzhou Kingred Electrical and Mechanical Technology Co.,Ltd is located in Suzhou city. Kingred is forcing on designing and building high performance CNC wire cut EDM, which is featured in : 1) unique high rigidity “C” structure design which is used for brass wire cut EDM; 2) closed-loop with servo control available to guaranty long term cutting accuracy; 3) accurate Taiwan HIWIN linear guideway and ball screw adopted; 4) “T” shape machine bed, “+” shape X and Y axes motion, much better mechanical accuracy then conventional wire cut EDM; 5) wire tension control system with linear guideway to avoid loose of wire; 6) Window XP based control system, easy to use; 7) brass wire EDM type clamping system, much more accurate than conventional fast feed wire cut EDM machine.
    Small hole EDM, also known as small hole EDM, EDM hole driller or EDM hole popper, is pretty similar to wire cut EDM machine, difference is that small hole drilling EDM use a long electrode tube to erode conductive material to create through holes or blind holes, usually, small hole EDM is used to make wire cut EDM start hole, filter hole, gas hole, group holes, it can machine various conductive material, even semi-conductive material, especially for stainless steel, chilled steel ,copper, aluminum, hard alloy; it can machine on the curve and slide surface directly; also can remove broken drilling tool and tapping tool without damage to original thread; working liquid could be normal water, low using cost and no pollution; we have two different type small hole EDM DB703 and DD703, DB703 had X/Y/Z axes DROs and DD703 had X/Y axis DRO display.
    Sinker EDM is another kind EDMs built by Kingred, sinker EDM is mainly used to make various cavity molds, mechanical parts. With or without X/Y axes servo controller, sinker EDM could be classified to ZNC control type and CNC type.
