From Cutting Tool Engineering-current issue. Interesting method of taper check. I suspect
Forrest had the last word on this when at the shipyard
Quote
"The propulsion drive shafts of Navy submarines, ships and aircraft carriers require maintenance about every 2 years.
That involves dry docking the ship or submarine at a Navy shipyard, removing the shaft, inspecting it for wear, filling
in any worn areas using additive techniques and then removing excess material on a lathe and with a hand-held grinder.
The shafts measure up to 30" in diameter and 60' or more in length. The current method for inspecting a shaft taper,
which has been the accepted practice for 50 years, utilizes a bluing fit. Resnick noted that there are a total
of five ring gages used by the U.S. shipyard community for inspecting such large shafts. Each gage weighs 500 to 600 lbs.
and is positioned onto a shaft using a sledge hammer with a specific weight and a prescribed number of hammer blows.
Then the gage, which has a bluing die applied to its contact surface, is removed and a group of inspectors collectively determine the percentage of bluing transferred from the gage to the shaft, with a good shaft having at least 80 percent of
the die. “If the shaft needs additional machining, it’s reinstalled on the machine tool and the process is reiterated,” Resnick
said. “It’s very time-consuming and very archaic.” The inspection process takes about 72 man-hours. “The standard rule of
thumb on what are called hotel services, or write-up expenses while in dry dock, is that they cost $250,000 a day minimum,” said Sean Krieger, project engineer with a specialty in repair technology at the Applied Research Laboratory at
Penn State. “So the clock is ticking the minute that submarine or ship arrives in the dry dock for refurbishment work.”
The Pearl Harbor Navy Shipyard asked ARL to help improve its metrology processes, including shaft taper inspection.
Before that initial project ended, ARL recommended using a Laser Tracker from laser measurement system provider
Faro Technologies Inc.,"
end quote
http://www.scribd.com/doc/22394302/c...g-October-2009
http://www.ctemag.com/
jh
