sa100
Hot Rolled
- Mar 12, 2008
- suburban detroit
Hello everyone, I just bought a old "Universal Boring Machine Co." 18" cast iron level. It is plainly ouit of adjustment, as the bubble position does not repeat when the level is rotated 180 degrees. The bubble appears to be of proper size. My initial reaction was to think of finding an instrument lab to calibrate the thing for me, but upon more thought I realized that I probably did not need a dead-level surface to calibrate the level, so long as the bubble is in the same spot with the level rotated either way.
I searched here and found a thread for Starrett levels where Leigh describes pretty much exactly how I would envision calibrating my level. My level has adjusting nuts that make it clear what needs to be done to adjust the level tube. So far, so good. Here's the complicating factor. One end of the level tube also has a pair of screws for adjusting the level tube from side to side as well as the up and down adjustment at the other end. I'm guessing that this adjustment is to calibrate the level when it's turned on its side, but it's hard, no, all but impossible, to see the bubble when the level is set on its side, plus there's only a very narrow strip, maybe 1/4" or so, of ground surface on either side of the cast iron body so the level can't even sit on its side all that precisely, or so thinks I.
So, that's my question. What are the side to side adjustments for, and will they complicate my effort to calibrate the level for normal orientation (flat) work? I am in somewhat of an enviable position, as the level is already out of whack and some gentle experimentation is unlikely to to make things worse. I'd like to have some idea beforehand what I'm doing, though.
Sorry if this is a dumb question, but I'm plowing new ground here.
TIA,
Steve
btw, has anyone heard of the Universal Boring Machine Co. of Hudson, Mass.? Are these levels any good? My poor old level has seen better days but is still in very usable condition, especially considering I paid $40 for the thing, complete with its original, fitted wood case. The bottom is well-scratched but shows no evidence of rust or of anyone having dropped it. The original (?) flaking is still visible. It looks to have been a handsome thing at one time.
TIA,
Steve
