ballen
- Sep 25, 2011
- Garbsen, Germany
I am learning to use a cylindrical grinder. I want to measure the taper with micron accuracy at many points along a cylinder, so a micrometer is not so handy for this. What I need is a "C-shaped" tool which I can put a Millimess or other micron-scale indicator into, then slide onto the cylinder at various points along the length. The end away from the indicator should be a flat hardened landing surface, perhaps a centimeter or two in size. (Or a shallow V?) Sort of like a lightweight dial indicator stand, which I can easily lift up to the work.
Ideally this would be able to handle the range 0-100mm, with perhaps another to go 100-200mm.
Is there a standard tool for this? I don't need the absolute diameter (or I can put in gage blocks for that, if needed). I just want to easily measure/monitor how the diameter is changing along the cylinder, without removing the work from the machine.
