Interapid 312B-2
ssturnin
May 7, 2006
Wis.
Been trying to put this this back together successfully. Replaced the whole body. So I had to completely take the parts out from inside and reassemble. I got everything back together to a point where the problem I'm having is the tip travel. Got the one spring that was in there back in. But there is only spring back in one direction. The other direction it's loose, no spring back. I'm so close to getting it, I just think I'm missing something. I really don't want to send it in. Any help is appreciated. Also, if I could get a clear diagram on the insides of this indicator that would maybe help too, Thanks.
indicator repair
HI I repair indicators
you will need to preload the hairspring. and when you insert it into the frame. find a way to keep the gear rack from moving. And then all the adjusting you will be doing once its back together. Don't lose a screw its $7.50 ea.
BOB
