awander
Stainless
- Jun 11, 2012
- Eastern PA
I was doing some measuring today and I was surprised by the results.
I bought an older B & S 233 bench micrometer recently, and when I first got it, I adjusted it so that when I closed the clean anvil/spindle faces using the ratchet, it read "zero".
Then yesterday, I used it to measure a round piece(it was a master thread wire that I wanted to make sure was in the correct vial). The micrometer showed that the wire was about .001" smaller than it should have been. So I figured it was in the wrong vial. But just to double check, I pulled out a gage pin and measured it. The gage pin, too, measured smaller than it was marked, by nearly .001".
Next, I tried using a gage block, and the micrometer measurement agreed with the marked size of the block.
My conclusion is that with the same amount of pressure(using the ratchet for all measurements) the micrometer will measure an object as larger or smaller depending on how much area on the measurement faces the object is in contact with. Does this seem correct to those of you who know about such stuff?
On a related note, I also found that I could get very different readings depending on how fast I closed the micrometer-it seemed that if I spun it a little faster using the ratchet, rotational inertia of the spindle/thimble would cause it to close down a bit more, measuring between .0004 and .0008 smaller on the same gage block. Even when I was careful to close micrometer on the block very slowly, I couldn't get consistent readings closer than .0002 or so.
